Location: Lemoore CA | That sounds kind of strange, I have seen them the other way around where the odometer works, but not the speedometer. Best advice, take it out of the dash, open it up and inspect it, you will most likely be able to see the problem fairly easy as they are completely mechanical. Both the speedometer and the odometer run off the same cable, so that is not the problem. I think if the odometer was frozen, it would not allow the speedometer to work. I am betting you have a broken or stripped gear on the end of the odometer. I have a odometer, NOS if you need one.
Edited by 5859 2008-01-06 1:21 AM
