1955 Dodge 259 POLY 2 BBL w/ 2 SPD POWERFLITE
mbmopar
Posted 2008-04-09 4:20 PM (#124455)
Subject: 1955 Dodge 259 POLY 2 BBL w/ 2 SPD POWERFLITE
Up for sale , approx 80 k miles, 259 Poly V8 2bbl, 99% complete air cleaner to oil pan, ** missing water pump and generator **
has, exh manifolds, distributor, starter, coil and bracket, carb linkage,carb, transmission adapter plate, convertor and 2 speed powerflite trans, trans has drum parking gear intact.
Most parts will fit or make a hemi( valvetrain and heads are poly specific ), the block is basically the same ast the 241 and 270 hemi. this engine was rated 10 hp less than the hemi.
all sheetmetal on this engine is nice, from an Arizona truck, no rotted out oil pans and flaky valve covers here. a fast bead blast and she's totally ready to go.
300 dollars, it's worth that in the parts. email preffered
Derek
mbmopar@hotmail.com
