AAJ Brakes? Check your bolts!
safetymike77
Posted 2004-09-19 8:47 PM (#13119)
Subject: AAJ Brakes? Check your bolts!
2000200050025
I was under my car doing some work, and I happened to spin both front wheels. Well, I found that the bolts holding my AAJ bracket were loose, and would partially rotate when I spun the wheel! Don't know if I forgot to tighten them, or they worked loose, but if you have a kit, check it the next time you have the front off the ground.
DeSotohead
Posted 2004-09-19 9:01 PM (#13126 - in reply to #13119)
Subject: RE: AAJ Brakes? Check your bolts!
Board Moderator
20001000100252525
Location: The not-so-great, dirty-white North ( Michigan)
I am a true believer in GREEN Loctite stud and bearing mount.
Used it on my AAJ kit. My bet is that to remove it, will have to warm it with a torch.
Daven Anderson
Posted 2004-09-20 12:19 AM (#13142 - in reply to #13126)
1001001002525
"to remove it, will have to warm it with a torch"
Sounds like removing brake drums from stubborn 57-64 tapered axle shaft rearends
Loctite Green, I second that motion!
62chrysler
Posted 2004-09-20 9:29 AM (#13149 - in reply to #13119)
Account Suspended (Steve Hobby Alias)
200010001001001002525
I remember stripping some AAJ bolts. . . Found out I needed to walk the bracket into place, tightening each one in a rotataion. I didn't have that problem with the new brackest though. My daily driver is fine though, but alas, I FINALLY sold it. Of coarse, I used a 3/8 impact gun on them. Maybe that was taboo
60 dart
Posted 2004-09-20 12:18 PM (#13174 - in reply to #13119)
50002000100050010010010010025
i spun the threads out of two of the bracket nuts-pass. side------it wasn't ROGERS product just too much tightening------my fault all the way------HELPFUL HINT------if you don't have LOCTITE you can use a dab of paint-just about any will do--------------later
