Location: Southern Sweden - Sturkö island | Can someone help me with this? I'm looking for the bi-metal spring to the right exhaust manifold butterfly. Is there any source for this? Has someone mounted a spring from another car/engine? What is the correct name for the spring in english? |
Location: northern germany | wiz, i never had luck finding a correct heat riser bi metal spring but found out that carburetor choke springs are almost identical and work just as good. go to ebay and search for choke spring, choke housing, choke cover, cap, coil, etc. you will find one cheap.
http://cgi.ebay.com/ebaymotors/Studebaker-1957-58-Golden-Hawk-Choke...
http://cgi.ebay.com/ebaymotors/ROCHESTER-QUADRAJET-CHOKE-COIL-HOUSI...
Edited by 1960fury 2009-12-26 3:54 PM
Location: Southern Sweden - Sturkö island | Thank you Sid, I suspected this when I checked my catalouges, but now you have confirmed it! Maybe I'm able to repair the spring, since theres some parts rusted away. |
