Location: new york | Hey guys is anyone making the rear antenna gaskets for the 57-9 ply & dodge rear antennas, I removed mine while it was in the interior shop and they got lost in the meanwhile. Please let me know! Thanks &HAPPY MOTORING! Victor... |
Location: Spencerport, New York | Check with Gary Goers, last I knew he had these available. Dick |
New User
| Am about to install dual rear slant antennas on 1957 Dodge Custom Royal. Need help with the proper placement wrt front of trunk lid. Thanks.
(58Dodge.jpg)
Attachments ---------------- 58Dodge.jpg (62KB - 184 downloads)
If someone doesn't beat me to it, there is a 57 Dodge Technical Service Bulletin that shows precisely where to
cut the openings for the rear antennae.
The initial TSB talked/showed drilling a couple holes on each side of the car, but, a revised TSB showed that long
oval openings should be made into the upper quarter panels.
I presume that you have everything that you will need, in order to do this job, including the wiring & splitter, etc.?
Location: new york | I did order from Gary goers a month ago still haven't seen them, Mabey by Christmas! HAPPY MOTORING! Thanks Victor |
New User
| Thanks. Have all required parts. Unable to locate Tech Bulletin. Just help with location wrt trunk lid. See photo.
(Antenna Location.jpg)
Attachments ---------------- Antenna Location.jpg (67KB - 157 downloads)
Location: bishop, ca | Ok; these should be self explanatory....
(PICT3843.JPG)
(PICT3844.JPG)
(PICT3845.JPG)
(PICT3846.JPG)
(PICT3848.JPG)
(PICT3848A.JPG)
(PICT3848B.JPG)
(PICT3848B1.JPG)
(PICT3848C.JPG)
(PICT3848D.JPG)
(PICT3849.JPG)
(PICT3850.JPG)
(PICT3851.JPG)
(PICT3852.JPG)
(PICT3854.JPG)
Attachments ---------------- PICT3843.JPG (52KB - 165 downloads) PICT3844.JPG (46KB - 160 downloads) PICT3845.JPG (96KB - 158 downloads) PICT3846.JPG (104KB - 167 downloads) PICT3848.JPG (58KB - 157 downloads) PICT3848A.JPG (103KB - 161 downloads) PICT3848B.JPG (103KB - 162 downloads) PICT3848B1.JPG (111KB - 162 downloads) PICT3848C.JPG (99KB - 160 downloads) PICT3848D.JPG (111KB - 167 downloads) PICT3849.JPG (100KB - 154 downloads) PICT3850.JPG (111KB - 165 downloads) PICT3851.JPG (105KB - 158 downloads) PICT3852.JPG (107KB - 163 downloads) PICT3854.JPG (100KB - 164 downloads)
Location: Fleetwood, Pa | Is that antenna that 1957Dodge posted a photo of a OEM Mopar antenna? I never saw one like that on a Forwardlook Mopar.... |
Location: Sept. 1958 | sidesho_bob1961 - 2011-12-12 6:13 PM
The second one, no. |
Location: Williams California | christine-lover - 2011-12-12 3:52 PM
The second one, no.
Second antenna looks like '57-'58 Mercury front fender antenna.
The ones pictured on the car look just like the factory ones I have removed from '57-'58 Dodges and Plymouths.
---John |
New User
| Thanks for all the help. You guys are sure observant. The Dodge antenna, below, refused to stand up for me to illustrate locater point I was interested in. By the way, the antenna in the picture is for a 59 Impala.
(Dodge Antenna.jpg)
Attachments ---------------- Dodge Antenna.jpg (52KB - 173 downloads)
Location: Fleetwood, Pa | I don't think this one is an original one either........You may want to do some more homework before you do something you may regret.... |
Location: bishop, ca | You may think it's mucous, but, it's-snot.
That ain't a Dodge dual antenna base, up there.
Location: Williams California | I'm fairly positive this is the type used by the factory-
---John
('59 SF convertible 008.JPG)
Attachments ---------------- '59 SF convertible 008.JPG (160KB - 160 downloads)
Location: Fleetwood, Pa | That's the type I'm used to seeing also........ |
Location: new york | Big-Ms photo is the correct Antenna the other is a aftermarket antenna, But its real nice and will look nice if your not going for Original. HAPPY MOTORING! Victor. |
Location: Blackpool, United Kingdom. | big m - 2011-12-14 1:16 AM
---John
Hi John, is this for sale i need a lefthand antennae, mine went missing while car being shipped, thanks Paul. |
Location: Williams California | springsweptwing - 2011-12-14 3:46 PM
---John
I'll see if I have another, Paul. This is one I am saving for a project.
---John |
Location: Blackpool, United Kingdom. | Ok John, that would be good, thanks Paul |
Location: Kennewick Wa | Hope you don't mind if I ask a question here. Does someone make new extensions? I have 2 good bases, but one of the extensions has been cut and other is badly bent. Also, both cables have been cut off.
Any ideas? |
Location: Perth Australia | The antenna that 57dodge has up there is the same as the ones I got from Johnny Rosen
Definately aftermarket.
(Duel antenea.jpg)
Attachments ---------------- Duel antenea.jpg (133KB - 166 downloads)
