Location: Chesterfield, Virginia | What are the symptoms of a leaking head gasket on a 59 361 engine? I may have that on a new rebuild. Thanks ahead. |
Location: central Illinois | Bubbles in the coolant, sudden explosion of hot coolant out the radiator fill, oil in the coolant, one or more cylinders not firing, coolant leaking out of the block, etc. Better yet, what symptoms are you having? |
Location: Chestertown, NY ( near Lake George) | Loss of coolant, white smoke out the exhaust, the hoses become pressurized ( hard) right after start up. |
Location: Chesterfield, Virginia | I'm chasing an exhaust leak type sound,sort of a loud" puff puff "on high idle. NO leaks in the exhaust though.No bubbles in the radiator either.Maybe I've got a lose spark plug.I'll check that when it cools down. |
Location: Atlanta GA USA | check for greenish tinge to spark plug(s). |
