Location: Torsby,Sweden | Hi i have a problem with my amp.gauge on my 56 Windsor it is going max to charge and the next moment max to discharge and suddenly it works allright and then suddenly it is for example stuck at max discharge or charge.
Any one got a clue of what is wrong perhaps the regulator or.......? The charging is about 14 volt so it is no problem with the driving but is really anoying to see .
Anders
Edited by windsor56 2012-03-10 2:24 PM
Location: Southern Sweden - Sturkö island | First thing Anders, check your wiring and connections, they must all have good contact without rust and/or verdigris - next thing to check is if your generator (?) has worn out brushes or a wobbling commutor - check with an extra amp meter temporarily hooked up. |
Location: Torsby,Sweden | Wizard ,wobbling commutor is that the collector you mean?I have tested the charging and it is pretty bad on low rpm but on 800 and higher it is on an even 13.5-14 volt levell.I will check everything one more time tomorrow.
Thanks! Anders
Edited by windsor56 2012-03-10 5:30 PM
Location: Netherlands | It's very normal for a generator to have hardly any charge at low rpm... |
Location: ZH, Switzerland | Yes, at the quite low (factory specs) 500 rpm the generator in my 56 New Yorker doesn't charge the battery. Or more precise the needle stays little bit below zero (discharging area). I have to give the engine about 1500 rpm to reach a good charging value. Then the needle stays steady between max and zero and goes to zero after few minutes.
I would check the ground wiring as well. Few weeks ago I noticed a wire from the pass side head to the firewall - just behind the cylinder head. I guess this connection is very important for the voltage regulator as well. As Sven said, I would check the brushes as well (in your case). What's about the wiring harness behind the gauges. Do the wires look good? And what's about around the ignition switch? By the way: did you check if there is a short circuit to ground (temporarily)? Good luck!
Happy Motoring!
Dieter
BTW: I had to jump start the engine of my moms A3 - engine finally running without jump start cables everything did start flickering and finally the engine (electronic ignition, electronic fuel injection) died. Unfortunately I cannot recall the reason (rectifier defect - at the Alternator or cell short circuit in the battery). Later on an elder Volvo drove by. Engine running really bad - cell defect in the battery), the owner told me later. If you don't find the reason in the generator, wiring and so on, I would try another battery. |
Location: bishop, ca | What about the operational condition of the voltage regulator?
Location: Torsby,Sweden | I have allready bought a new battery so I think that is not the problem. I am comming from the garage in this minute and for the moment when I started the car the gauge worked really fine ,thats the issue every time i will look at the charging problem it is working allright thats anoying. Thanks for the help
/Anders |
