| I am restoring a 56 Coronet that I bought in various states of dis-assembly. Before I got it person(s) unknown had cut the wires that came out of the bottom of the steering column. There is a pigtail there that has a green wire and a brown wire that I figured must go to the turn signals (right?) There are 4 other wires that I can't figure out where they should go. Red (flasher socket?) Green (horn?) white (stoplite switch?) and a brown wire (unknown) If the pigtail w/the brn & grn wires go to the signals I want to be sure where the loose RED, GREEN, WHITE, BROWN wires go. I have tried to study the diagram from the shop manual but I just get confused. This is a former CHP Coronet 2dr sedan, powerflite and was originally delivered w/the 315 poly engine. Any help or guidance would be most appreciated. Jerry Boyle email if you want to contact me other that on this forum is: ret5395@earthlink.net | |
