Headers
Whale
Posted 2012-03-25 7:12 AM (#313742)
Subject: Headers
Any tips,tricks or advise on installation of
Sanderson block hugger headers in a stock frame
on a 55 270 Hemi.
thank-you
MH Neuman
d500neil
Posted 2012-03-26 4:19 PM (#313924 - in reply to #313742)
Subject: RE: Headers
5000500050002000200010025
Mike, you should look at this thread, for Tom's customization of Sanderson Block Hugger
manifolds.
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=33298&...
The 55-57 Dodge Hemi heads will have the same exhaust ports, but, the 55-56 guys have
different motor mounts (IIRC) and different (coil-) springing, so the Sandersons may well be
bolt-on assemblies on both sides of the engine.
However, as an alternative to the customization of the Sandersons, these custom headers look
like they will easily fit onto the 55-56 applications, and, probably, to the 57's too.
I like that the front runners are siamesed, as the exhaust pulses on them will probably help to
scavenge the fumes, and, the elevated, transverse front runner (at least, on/for the 57's) will clear the
motor mounts.
If you or your shop has mechanical-welding capabilities, then creating a version of these headers may
well flow better and be more efficient (by creating long-runners, to where they eventually reach their
flange-connections) than the Sandersons.
Edited by d500neil 2012-03-26 4:23 PM
(Custom headers.JPG)
Attachments Custom headers.JPG (118KB - 98 downloads)
