Posted 2012-06-18 3:02 PM (#326086) Subject: power window switch connctor
I need one connector that connects the wiring loom to the power window switch for a single switch. If I read the parts book right, the part # is 1779268 and is common across all the divisions for '57 and '58.
Maybe for '59 too, but I didn't look that part of the parts manual up.
Posted 2012-06-20 4:13 AM (#326288 - in reply to #326279) Subject: Re: power window switch connctor
Small advice: don't crimp the wires - solder! A high tear-resistant and a low electric-resistant are important for the power windows. I just have added some pictures for you in the mentioned thread for illustrate.
Without a connector, in my case (see last Pic) I would solder the wires directly around the pins of the switch for leaving flat to the left, the main connectors being then the external (soldered) round crimp-connectors. - SERGE -
