| So I removed the cotter pin and the center nut but I cannot seem to get the drum off. Do I need a puller to remove this? Hopefully someone is online this afternoon so I can wrap this up today. Thanks guys! |
Location: Minnesota | Yes, you need drum puller. The type that bolts to the wheel studs. And presses against the center axle shaft. A quick search of eBay for drum pullers will reveal the type you need. You may be able to rent one locally? |
| I managed to rent on a AutoZone. I had to use one for a front wheel drive hub. The drivers side came off easy. The passenger was a bear. Unfortunately for me the drivers side looks like it needs an axles seal. The right side needs a wheel cylinder. |
