Location: Washington State, the wet side | Sold the car a few years ago still have the motor and original trans. Motor was machined and need some final assembly.
EGGE Machine Parts $1,467
Eastside Machine Machine work $3,070
Hotheads Parts, Freeze plugs, Adj Pushrod set $218
Hotheads Trans adapter $562
Hotheads Mini starter, Harmonic Balancer
Motor mount kit, remote oil filter
Dip stick, Mopar dist adapter,
Spark plug tubes, rubber seals $759
Eastside Machine Machine work &326
total (not including core) $6,402
This is what I have spent on this motor. The block has been totally machined, reground cam and crank. All new pistons bearings timing gear etc etc.
Pickup only in Seattle area $3,000
Location: Washington State, the wet side | And the items below !
$6,000+ is what I spent not including the core! asking $3,000
Edited by haspe 2014-04-24 9:01 PM
Location: Washington State, the wet side | I still have a the 341 DeSoto Hemi, make an offer
Eastside Machine Machine work $3,070 (Prob paid to much)
Eastside Machine Machine work $326
total (not including core) $6,402 (not sure what I was thinking)
This is what I have spent on this motor. The block has been totally machined, reground cam (345 spec) and crank. All new pistons bearings timing gear etc etc.
In Seattle area $3,000
Edited by haspe 2014-12-18 3:38 PM
Location: Washington State, the wet side | Make me an offer, need it gone | |
Location: New Castle PA | Haspe, I can't afford an extra engine right now, but do you happen to know (or can you look for ) the engine NUMBER? I'd like to have it for my 1957 DeSoto database. It's stamped on the flat area just ahead of the water pump, to of engine, kind of under the thermostat, and should be either S25-xxxx or S26-xxxx. Thank you! | |
Location: Washington State, the wet side | S25-3504 and 4039 above that number | |
Location: New Castle PA | Guess I should have looked up your real name first, before asking for that number! I already have that engine in my database, but I didn't know (or didn't remember that) you had sold the car. You also had a non-salvageable Fireflite. Do you still have it?
THANK YOU. | |
Location: Washington State, the wet side | Motor sold | |
