| Anyone convert a non-power steering with original power steering parts from another car? What I am wondering is... Are the columns the same? I have the gear box, pump, pulleys, hoses (new) and column out of another car. I'm hoping that the column is the same so that I don't have to change that. Is this possible? Thanks! | |
Location: Hay Lakes, Alberta, Canada | No, the column is different. Standard and power steering columns are not interchangeable. | |
| Thanks Brad (disappointed!) Cheers, Kirk | |
Location: Montreal, Canada | You might find some interesting info in here too, as I am having a problem similar to yours.
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=50349&...
