fuse locations 1960 Dodge
jimntempe
Posted 2014-09-15 5:50 PM (#456384)
Subject: fuse locations 1960 Dodge
2000100100100
Looking for info on where the fuses are in my 60 matador. I have a wiring diagram but it seems to provide no info on where the fuses are. I did a search here on forwardlook.net and didn't find anything. I got the idea somewhere that there is a fuse right on the switch for the variable speed wipers. And I got the idea that there was one or more fuses on the headlight switch. Crawling under the dash yesterday (I thought I'd blown a fuse but it turned out I didn't) and looking up toward the Headlight switch I was not able to see much of anything but wires. Now that I've gone looking and can't find them it worries me as to what would I do if a fuse blew away from home? Hard to replace what you can't find.
So where are the various fuses located? How many are there? Anybody got any info?
ttotired
Posted 2014-09-15 6:02 PM (#456389 - in reply to #456384)
Subject: Re: fuse locations 1960 Dodge
50002000100010010010010025
No fuses (except for the radio)
It has circuit breakers, the one on the wiper switch is the easiest to see, its a tin box, about 1 " long x 1/2" x 1/2", 1 wire on it, the output goes to a metal link thats on the switch
The circuit breakers are auto reset, so provided you dont completely cook it and you work out whats causing the short and fix it (if it does trip out), you can just keep going as it resets itself
fenix
Posted 2014-09-15 6:17 PM (#456394 - in reply to #456389)
2000100
Nick, We need to talk!
VAN HELSING
Posted 2014-09-15 11:05 PM (#456451 - in reply to #456394)
500100100100100252525
When I first got my Dodge I looked for ages for a fuse somewhere/anywhere only to find from a fellow forwardlooker later on that it didn't have any.
I share your frustrations.............
60 dart
Posted 2014-09-15 11:46 PM (#456457 - in reply to #456384)
50002000100050010010010010025
there should also be an inline fuse for the heater . how do i know , well i blew out about 6 of em tracking down a short ----------------------------------------------later
jimntempe
Posted 2014-09-17 8:41 PM (#456630 - in reply to #456384)
2000100100100
So .... One is on the wiper switch. There is a fuse for the heater. Usually the headlight switch has a built in circuit breaker, is that true here? What other circuit breakers are there and where are they?
60 dart
Posted 2014-09-17 11:59 PM (#456647 - in reply to #456384)
never had a light switch apart or even thought about it , don't know about that one . the variable speed wiper switch's little box actually says "littel fuse" and correct spelling --------------------later
