1960 desoto codes
guyman
Posted 2014-10-10 12:09 AM (#458679)
Subject: 1960 desoto codes
Need some help decdoing please...can't find info on my paint code...on my metal tag I have...
On the alphebet codes as stated below on my metal tag I have A2, N5, T2
abcdefghijklmnopqrstuvwxyz
2.                 5.       2
Then below that I have...
so.            Number.              Body.            trm.           Pnt
0209           3173                   722              801          WD2
thanks for the help, Guy
guyman
Posted 2014-10-10 12:21 AM (#458680 - in reply to #458679)
Subject: RE: 1960 desoto codes
Got most of the info already accept....what the A2 is for , the number 3173 under the number , and finally the trm code of 801...I found everything else out. I know the 80 is for style and material and the 1 is for color...I just don't know which material or color.
Edited by guyman 2014-10-10 12:28 AM
CustomRoyal
Posted 2014-10-11 5:04 PM (#458857 - in reply to #458680)
Code 801 is a blue Adventurer interior. Blue cloth with designs, blue bolster, and white vinyl accent. Interior is called Fiesta Jacquard. Code 722 is an Adventurer Sportsman 2dr hardtop.
Jim
Edited by CustomRoyal 2014-10-11 5:59 PM
guyman
Posted 2014-10-14 4:33 PM (#459213 - in reply to #458857)
Thanks Jim for the info....
now just need the A2 and 3173 de-coded
Guy
nashbearwa
Posted 2015-03-08 3:50 PM (#471991 - in reply to #458679)
Subject: Re: 1960 desoto codes
It scheduled build date is 02/09/59 Monday Feb 9, 1959....The number 3173 is the Plant Production Sequence Number So it's the 3,173 car built at that plant.
59 explorer
Posted 2015-03-08 7:09 PM (#472004 - in reply to #458679)
100100100252525
From the NDC
0209 car made on Feb, 9, 1960
3173 production code; needs verification, may be the 173th Desoto made that day or the 173th car made that day or??? hopefully Chryco can help
722 Adventurer 2 dr hardtop as noted
801 interior as noted
WD2 Shell white top/Artic blue body
There should be a metal VIN plate beginning with 7203-1xxxxx by the driver's side door hinge 7 = Desoto 2 =Adventurer 0 = 1960 3= Jefferson plant
