Posted 2015-01-13 3:05 PM (#467482 - in reply to #467375) Subject: Re: spin on oil filter adapter 57 Plymouth 301wanted
Paul. Just get a factory spin on adapter off a '62 and up Poly 318. It bolts right on and you can use the spin on filters. LA blocks are probably the same too.
I can probably hook you up with one actually. But it might cost you a '59 Plymouth!
