| My Torque converter drains back into the trans pretty quickly
Assuming the torque converter is OK is there a valve or seal or something in either the
Valve body behind the front pump or in the main valve body
that is supposed to keep the oil in the torque converter from draining back into the trans
when the engine is not running
Any suggestions would by appreciated
Thanks Larry | |
