Timing chain
T-34
Posted 2015-04-25 2:28 PM (#476590)
Subject: Timing chain
Is there anyone know of a good source for a timing chain set for a 383 1959?
Magnus
Posted 2015-04-25 4:32 PM (#476599 - in reply to #476590)
Subject: RE: Timing chain
20001000500100100252525
Do you want a stock replacement set or a double-row roller type?
T-34
Posted 2015-04-26 12:49 AM (#476634 - in reply to #476590)
Subject: Re: Timing chain
I really dont know. Is there a big difference in quality and price?
59 in Calif
Posted 2015-04-26 12:07 PM (#476677 - in reply to #476590)
Without a doubt, go with the rollar chain. As I remember, wasn't much difference in price when I did my 413, 4 -5 yrs ago. Got the parts at NAPA. Jerry
T-34
Posted 2015-04-26 12:37 PM (#476680 - in reply to #476590)
Thanks for the info
Posted 2015-04-27 8:42 AM (#476763 - in reply to #476590)
From my experience.
Be aware that I think the early big block castings differ from the later models. Carefully check the camshaft sprocket to engine block clearance. Both of the sets I purchased interfered with my 1959 built engine block casting. First set was destroyed, second set required the camshaft sprocket back side machining to give clearance.
The first set chain was stretched and the noise sounded like the worst big end bearing failure you ever heard. This was on my refreshed engine, and took a complete engine strip to find.
Steve
T-34
Posted 2015-04-27 1:43 PM (#476778 - in reply to #476590)
I'll keep it in mind. Thanks Steve
Magnus
