Hi
Someone who can help here, thing is that I wonder if the split radiator fan schroud for Chrysler 300 57.58 with A / C, can be replaced with a ditto from Imperial?
I have the original 5 blade 18 inch fan and missing the old clutch, what clutch fits my car when I want to switch to new one? the original was of viscouse type I suspect. What clutch dimensions and brand is recommended here?
Thanks Michael
Posted 2015-06-19 10:07 PM (#482078 - in reply to #482061) Subject: Re: Radiator schroud & clutch 300C,D
I am not aware of ANY fan clutch that is a direct interchange. There is a member of the 300 Club that machines down a current clutch I think from a Jaguar. I ordered one about two years ago and have heard nothing.
If the Imperial shroud halfs work that would be great. I need a lower half.
In the meantime I am running a 6-blade Imperial fan on my 300C with only upper shroud. Ran fine at 90o last weekend into the 'big city' traffic.
Posted 2015-06-20 12:33 AM (#482082 - in reply to #482061) Subject: Re: Radiator schroud & clutch 300C,D
Hola Michael
..The OEM Silicone Fan Drive that was OEM in 1960 was "enhanced" in later years by The Thermo - Silicone Unit. Your first series unit went to second class power plants and like cars.
The since then unit is Number 303-271 at NAPA and like places. It not only "fits" - but will accept The Torque --- with out any alternations.
... The same Engineering Improvement was applied to The Engine Cooling Fans. Any 1985-1980 Engine Cooling Fan from any pick and pull - Rear Wheel Drive, GM or MoPar
will bolt to #303-271. The newer Engine Cooling Fan will use less energy from The Engine - while moving a Higher Volume of Air.
Posted 2015-06-20 9:15 AM (#482103 - in reply to #482061) Subject: RE: Radiator schroud & clutch 300C,D
1960 des - 2015-06-19 6:30 PM
Thanks Michael
check this thread. dimensions listed. should fit your car.
Posted 2015-06-20 10:57 AM (#482109 - in reply to #482061) Subject: Re: Radiator schroud & clutch 300C,D
The original post asks about '57-58 300C and 300D. There is no interchange for that part that will fit. The part for the B and RB engines will not fiit the '57-58 Hemi.
