Location: northern germany | someone has an explanation why the inner headlights are on and the outers not in this clip? actually this is not possible the way they came wired from the factory. could be a 50s florida thing but the non mopars are regularly lighted. 60 plymouth, 60 dodge, 59 imperial:
https://www.youtube.com/watch?v=w9ChMimDna4&index=10&list=FL0gdUx4gf... |
Location: Southern Sweden - Sturkö island | That looks totally wrong Sid - you have a good eye for details - I perhaps would have missed it.
I don't have a clue............... |
Location: Royal Oak, MI | Two white '59 Imperial converts used -- the one early on has the plain trunk lid and the one in the nighttime shots has the Flite Sweep ("continental") lid. |
Location: Newcastle Australia | I don't have an explanation, but I have seen it twice on inports to Oz. One 59 Dodge and a 59 Imperial. Both had RH and LH head light assemblies swapped to the other side and the wiring swapped so that the inners were Hi/Lo and the outers were Hi only.
Location: Montreal, Canada | I would never trust something out of a Hollywood movie.. They might have disconnected the outer pair so the headlights wouldn't be too bright in the shot. |
Location: northern germany | soiouz - 2015-08-19 7:35 AM
this could it be. but it would mean the cars had the high beams on, so if too bright, why using the high beams and why not disconnecting the inners so that it would look natural and the cars still had the low and high beams? makes no sense. i guess i have to live with it that i will never know
reminds me of the film "the marriage go round" with a pre production 60 fury with, for some reason, disconnected tail/license lights.
Edited by 1960fury 2015-08-19 7:58 AM
Location: northern germany | lozrox58 - 2015-08-19 3:04 AM
not easily possible in 60 plymouths as the high beam only (inner) wiring wouldn't be long enough. |
Location: Montreal, Canada | 1960fury - 2015-08-19 7:57 AM
Yeah, I thought of that too.. but aren't the inner light "aimed" higher than the outer pair?.. If so, since the camera is almost ground level in that shot, it would make sense to use only the lights that are aimed higher.
