swapping out flat tops for dome pistons early hemi
dodge59
Posted 2015-08-30 5:51 PM (#488355)
Subject: swapping out flat tops for dome pistons early hemi
1000
it's been about two years since my 241 hemi rebuild and it now has approx 1500 miles on it, not even broke in yet. ,,,engine  runs great and I am thinking about installing a set of Ross forged high compression 10.1 pistons in the 241 hemi. question is ,  will my old stock rod length work with these new domed piston ?
I'm assuming they will because the dome is the only thing different protruding into the cylinder head chamber.
will I have to rebalance the rotaing assemble again with the new pistons ?
I'm pulling the engine out anyway and would like to make a change on it
It does have a step up on a reground neilson's cam in it already with ported and polished heads. what are your views ? I'm NOT  looking to race the engine by any means  but am looking to increase  horsepower and the fuel mileage on the dodge.
you can see the full step  by step  Hemi rebuild  full atricle in search of " rod knock in my 241 hemi"
Thanks  guys
