Location: Washington State, the wet side | I am converting my -60 DeSoto cast iron transmission to a -62 727 trans. Just realized that the linkage is not the same and assume that I would have to locate a -62 throttle bell-crank match up to the later trans. Does anyone have any pics of a 62 linkage set up and would it bolt up at the same location on the firewall? I have both the -60 and -62 linkage that mounts to the trans but only the -60 bell-crank that mounts to the firewall |
