I have two full sets of 1957/1958 Plymouth Front Brake Drums. Also, one set has the spindles and backing plates. I also have two sets of rear brake drums. Plus I have two complete axles, one is a 3:15 the other is a 3:17. The 3:15 came out of a 1958 Fury and I removed the drums and axles as well as the differential, so I can sell part or all, I could even reassemble. The 3:17 is whole as it came off of my 58 Savoy. Assume all brake cylinders are bad as they have sat for a while.
I hate to use these for scrap if someone needs these, especially at only $40 a ton. Make me an offer. As long as it is worth my time to pack and ship I am good with it. I am pretty sure the drums can be sent priority flat rate for around $13.00 so $20 plus shipping for each drum should work. I will check actual wear before shipping so you know what is left to turn.
Obviously the rear axle parts are a little more work to package up and shipping cost is dependent upon location and item.
Just send an email to clifdavis@clifdavis.org or you can text me at 971-221-2362 and we can go from there.
Not looking to make a bunch of money here, just want someone to use what they need.
Thanks, Clif
Location: Pacific Northwest | What size are the rear drums? I'm up in Seattle and am having brake drum difficulty. I'll call you in the AM. |
Location: Alaska | That is interesting, are you sure the 3.15 in your Fury was original? All 3 of my 57-58 Furys had 3.31 ratio. |
