| Are the rear drums on a 57 and 58 truck d100 interchangeable ? My truck has two cylinders per wheel and I kno of a 58 brake setup for sale with the same. I coulda swore I read they were but can't confirm | |
| AS indicated, the listing on that drum is 1957 - 1958 D100 Rear -- so if his rear is original, you are set.... Because, as we know, unfortunately, that Brake Drum
just DOES NOT EXIST on planet Earth Brand NEW.....
Good luck, Mike .............. Craig. | |
