Steering column removal
flyinbuttress
Posted 2016-08-04 1:29 PM (#518352)
Subject: Steering column removal
Anybody tell me how a non power-steering column comes off the gearbox? I removed the pinchbolt and slid its collar up out of the way. The pinch bolt and collar were on a tube with a 2in split that meets up to the gearbox and I can only move the tube back a 1/4in or so. Didnt wanna mess anything up so I figure Id defer to the masters. Thanx for any help.
flyinbuttress
Posted 2016-08-08 1:41 PM (#518601 - in reply to #518352)
Subject: Re: Steering column removal
Nobody on this? Just trying to figure out how to get the box separate from the steering column shaft. Thanx
Posted 2016-08-08 4:34 PM (#518626 - in reply to #518352)
5000
I am about to tackle that... uhg
ttotired
Posted 2016-08-08 6:09 PM (#518637 - in reply to #518352)
50002000100010010010010025
You havnt said what car??????????
Anyway, on my 60 dodge with manual steering, you cant remove the column/shaft without stripping the actual box
Undo the pitman arm off the box (only fits on in one spot, it has a "blind spline") Take the mounting bolts out and note how the washers and the wedge are set up (photos are good) and it should come down and out.
Not sure if you need to remove the column jacket to get it out on yours, but I would take it off anyway and also make sure you have the car jacked up enough in the front to allow it all to drop out.
LD3 Greg
Posted 2016-08-08 10:25 PM (#518659 - in reply to #518352)
Subject: RE: Steering column removal
If the column is released from the dash it should just pull straight up now.
Greg
LD3 Greg
Posted 2016-08-08 10:27 PM (#518660 - in reply to #518659)
I assume you have removed the steering wheel and horn wire.
flyinbuttress
Posted 2016-08-08 10:35 PM (#518663 - in reply to #518352)
What an idiot.. I didnt say what kind of car LOL! I need to fire my proofreader! Its a 56 Dodge Royal. I have removed the wheel and horn wire. I may just pull it down with the gearbox. I dont really need the gearbox but what the hay. Thanx guys.
