Location: Harrisburg, Penna | WHO SELLS 2 \ 4Bbl CARB IN LINE MOPAR LINKAGE??????
RON |
http://www.ebay.com/itm/66-71-Mopar-426-Hemi-Cuda-Charger-Carter-Ca...
http://hothemiheads.com/hotheadspi2.html#L
Edited by mstrug 2017-01-06 5:29 AM
Neil Jenks
Dynamic Renovation
248-476-6793
Fuel lines, pump to carb: OE $55, SS $65
Brackets (coil, throttle return spring, spacer if Non A/C) Non A/C: $85, A/C: $80
throttle Return springs: $25/pr
phenolic spacers: $40/pr
carb base gaskets: $10 for 2, 4 are needed
air horn gaskets:$7.50 ea 2 needed
inlet fitting w/1/8" npt for front carb: $25
inlet fitting strainer: $7.50 ea, 2 needed
throttle cable bracket: RB or B engine $35
All look NOS
Mark |
| Hello Ron
This might help
http://www.brewersperformance.com/proddetail.asp?prod=HPL
(HPL.jpg)
Attachments ---------------- HPL.jpg (4KB - 169 downloads)
Location: Whetstone, Arizona | Offenhauser sells the linkage kits |
Most of the dual-quad progressive linkage kits are cluttered and ugly, the Brewer's offering is the cleanest installation but it requires the installer to compute the leverage points on the carb levers that will result in both carbs reaching WOT simultaneously.
Of course, if you don't want progressive linkage just install a single rod between the carbs. |
