Rear glass trim
bshopov
Posted 2017-01-26 2:20 PM (#532404)
Subject: Rear glass trim
Hello Everybody,
Please tell me is it compatible Dodge 59 sedan rear window trim with trim rear glass for Plymouth 59, both cars are sedan, not hardtop
Thank you for opinion
Chrispy
Posted 2017-01-26 3:28 PM (#532410 - in reply to #532404)
Subject: Re: Rear glass trim
500
Those should interchange.
bshopov
Posted 2017-01-26 3:50 PM (#532411 - in reply to #532410)
So it means that I can put rear trim from Dodge 59 to Plymouth 59.
Posted 2017-01-26 6:38 PM (#532420 - in reply to #532404)
50001000500
YES!
59 in Calif
Posted 2017-01-27 1:04 AM (#532442 - in reply to #532404)
I found trying to reinstall that rear glass trim to be a really big PITA. I also found out the rear glass has to be removed to install a new headliner. So I removed the rear glass again after fitting the aftermarket seal. I'm putting the side window seals and windows in and getting ready for the upholstery shop. Let us know how you got the trim back on as it locks into the seal also. So am saving this nightmare for last. (59 Dodge 2dr sedan) Jerry
