Location: WHEELING,WV.>>>HOME OF WWVA | will the gas gauge on a 60 dart still work , if the oem oil gauge/dummy light is replaced with a mechanical gauge , taking the oem oil gauge/dummy light
out of the equation ---------------------------------------------------later |
Location: WHEELING,WV.>>>HOME OF WWVA | did all the smart people leave ---------------------------------------------later
Location: Perth Australia | Fuel and temp are the only 2 that use the regulator
Should not be a problem
Location: WHEELING,WV.>>>HOME OF WWVA | thanks perth . i was under the impression all the dash gauges were linked ---------------------------------------------------------later |
Location: Camptown PA | Perth's right. I'm running mechanical oil, temp and alt gauges on my 60 and the fuel gauge still works |
