| Need a new brake master cylinder so many options in my eBay/rock auto search, also do I use existing pushrod? If so what is the best way to remove? Part number off my car reads 297850 made in USA. Any help would be greatly appreciated my son recently bought a 57 2dr hardtop.
Thanks
Scott and Joel | |
Location: Lower Mainland BC | 6 numbers is not Mopar/Chryco part number. Should be 7.
The M/C for the 57 is probably the same 1.125" bore as the one for my 56 Custom Royal. Easily found at Rock Auto:
Four nuts and one hose. You re-used (don't touch the activation rod - the M/C slips over it.).
http://www.rockauto.com/en/catalog/dodge,1956,custom,5.1l+315cid+v8...
http://www.rockauto.com/en/catalog/plymouth,1957,belvedere,5.1l+313...
Edited by 56D500boy 2017-05-29 2:28 PM
| Or ------------- if you would like to avoid the Chinesium world --- I have the master cylinder, all 6 wheel cylinders, the brake hoses, the brake shoes in N.O.S. ++ asbestos == for continued nice smooth braking, etc., etc.
and tons more for this car.....
You are welcome to call me -- Craig -- 516 - 485 - 1935 ... Long Island, New York..... | |
