Location: Ocean Park, Washington | Needing a power brake bracket assembly for under the dash. This situation is pissing me off with what I have been trying to accomplish. A body from a manual brake, fitting a power brake assembly to it. The bracket assembly I received from Williams California isn't working. He sent me a brake pedal arm that is for power brakes. Good, until I tried to set it in place into the brake bracket assembly. Too wide, that spreads apart the bracket, and a little too long for the shaft to squarely meet the master cylinder.
I need a 1956 Chrysler power brake assembly that is correct and won't set me back too much more. Thanks. |
