| need following small parts, if stripping a car you may have them.
1) steering wheel, good or rebuildable, cancellation tab not broken or cracked
2)mechanical part of the directional switch with the stalk.(have electrical)
3) bulb holder inside trunk, over the license plate ; I have the plate holder "box"
4) odometer plastic pieces, (or complete replacement ) with free spinning number wheels, legible ? replacement part?
5) screws with insulators that hold it, and the horn disc switch
6) speedo "box" complete with good red and orange tube (end pins not broken off) ; if tube spins or speedo box still together it is probably ok
7) dome light lenses , can fix crack but pin that holds it to metal at one end must be intact
8) radio antenna front mounted
9 ) body panel below trunk lid if the slot for rubber is intact .
Thanks for help opr comments, too,
Best regards, John | |
Location: So. Cal | For #5, you can purchase those new on Ebay.
https://www.ebay.com/itm/ORIG-1959-1966-MOPAR-HORN-SWITCH-SCREWS-WIT...
Edited by Powerflite 2017-11-20 2:01 PM
Location: Newark, Texas (Fort Worth) | Nos antenna on Epay...
https://www.ebay.com/itm/1957-59-Dodge-Plymouth-Desoto-Chrysler-Fron...
Edited by mstrug 2017-11-20 12:35 PM
Location: Falcon, CO | John, PM sent. Also check with Big M as he will have some of the parts that you need.
Don H. | |
