Location: Winston Salem, N.C. | hi available to me are 3 door latches. below are the part numbers--best i can read them, hopefully correct. i need to know what style of 56 plymouth they fit and whethwe each is for a 2 door ht, sedan, 4 dr ht or sedan
thankyou for your help.
jerry whitfield
winston salem, n.c.
can't hardly see but think 30707 30802 21871R
Location: Eastern Iowa | Probably those are casting numbers and quite meaningless.
The part number on those types of parts would be found on the parts box they came in.
I'm thinking you have these parts in hand w/no boxes and with no idea whence they came??
Edited by finsruskw 2017-11-25 6:58 PM
Location: Lower Mainland BC | Jerry: Those Part Numbers (PNs) don't have enough numbers in them. Should be 7 numbers, like 1234 567 (four numbers, a space, and then three numbers). The PNs of the door locks are flagged as being in section 23-18-5. See below.
Edited by 56D500boy 2017-11-25 7:32 PM
(55-56DoorPartDiagramFlaggingTheLockInSection23_18_5.jpg)
(Section23_18_5_55DodgeAndPlymouthDoorLockPNs.jpg)
(Section23_18_5_56DodgeAndPlymouthDoorLockPNs.jpg)
Attachments ---------------- 55-56DoorPartDiagramFlaggingTheLockInSection23_18_5.jpg (161KB - 99 downloads) Section23_18_5_55DodgeAndPlymouthDoorLockPNs.jpg (198KB - 106 downloads) Section23_18_5_56DodgeAndPlymouthDoorLockPNs.jpg (207KB - 101 downloads)
Location: Lower Mainland BC | Jerry: There wasn't a conclusion to your thread. If you are still trying to figure it out, I suggest posting photos of what you have so we (those with 55/56 Dodge or Plymouths) can compare and advise.
