Hi Guy's,
I'm starting to reassemble my Fury do the door handles have a gasket between the outer handle & door panel ?
mine had nothing when I removed them just not sure if it's suppose to have gaskets or not.
Thanks Gra |
Location: northern germany | no gaskets from the factory |
Thanks Sid |
Location: northern germany | when you put them back on after the paint job use extreme care, you may want to shim (with washers) the bolts so the sharp edges do not damage the paint, the factory paint was more forgiving and flexible than the newer paints. you may want to use sealer between the handle and door but this makes the handles extremely hard to remove.
Edited by 1960fury 2018-01-27 2:17 PM
Thanks again for the info Sid. I have another question my 60 has a dash pad that the previous owner started to recover I don't know
what it is suppose to look like does your 60 have a dash pad ?
I can't find a pic of a 60 dash pad anywhere
Cheers Gra |
Location: northern germany | my oe dashpad is still there but i fixed it with polyurethane and unfortunately painted it with a rubber paint that does not like heat. now 27 years later it looks weird and not stock anymore the oe 60 fury dashpad is plain, with a leather like surface and without any ornamentation, unlike 61.
this is exactly how i remember it (only in black):
http://www.justdashes.com/2011/10/1960-plymouth-fury-dash-pad-repro...
Edited by 1960fury 2018-01-27 6:13 PM
I've done the Google thing never had any luck till now
Cheers Gra |
Location: Newcastle, NSW AUSTRALIA | We found it at the same time lol |
Location: northern germany | yes are you going to buy a dashpad from justdashes? can you find a price on their website? these look so nice i consider buying one. |
Location: Newcastle, NSW AUSTRALIA | I am going to email them & find out cost + shipping will let you know |
They have replied with $500 for the dash pad + $100 to $200 for colour matching + shipping.
At that rate I think I'll get the trimmer to recover the 1 I have
Cheers Gra |
Location: northern germany | okay, thanks for letting me know! i think my dashpad doesn't look that bad |
