Brake pedal pin
albjerryg
Posted 2018-05-04 10:45 AM (#562789)
Subject: Brake pedal pin
I want to remove the brake pedal pin to get at the brake push rod. I am wondering if I am missing something. I have the hair pin out of one side of the pin and I can flex both side of the yoke but I can not drive the pin out. Is there something else holding the pin in???Thanks Jerry
(19.JPG)
Attachments 19.JPG (28KB - 140 downloads)
Posted 2018-05-04 12:13 PM (#562794 - in reply to #562789)
Subject: Re: Brake pedal pin
50001000500
friction. whack it once. Or spray some liquid wrench on it go eat lunch and see if it moves.
Edited by mstrug 2018-05-04 12:15 PM
albjerryg
Posted 2018-05-04 5:44 PM (#562811 - in reply to #562794)
I was able to unscrew the rod and get it out but no luck with the other part. I did spray and wacked it no movement. I try and spray it and let it set over night. Thanks Jerry
local2Ed
Posted 2018-05-07 8:10 AM (#562902 - in reply to #562789)
Subject: RE: Brake pedal pin
500252525
See if you can get vice grips or a small pipe wrench on the big end and try to turn it clockwise/counter clockwise.
