Location: So. Cal | '57 Dodge 325 poly motor with complete 4bbl setup including intake, choke, carb & air cleaner. Motor has been disassembled but is complete with exhaust manifolds, generator & starter & all small parts on the inside, but is missing the pulley on the water pump. Block looks to be good, and I would expect it to clean up at .03" over. Crank is standard and hasn't had bearing issues, but will likely need to be cleaned up because of sitting apart. I'm asking $850 for it, but I have no idea how to ship it. You will need to pick it up in the Los Angeles area. I'm not willing to sell any parts separately unless the block sells first. |
