Location: North Australia | Check out this rocket ship! No reserve.
Steve.
https://www.ebay.com/itm/1961-Chrysler-WINDSOR-NO-RESERVE/1238890575...
Location: Victoria, BC, on Vancouver Island, Canada | Wow, custom 61 Canadian built Windsor - with a 62 New Yorker grille emblem, and cross rams. There are quite a few mistakes in the lengthy description. |
Location: Sydney, Australia | Nice car if bought/won at the right price..
Location: Alaska | What do they mean the engine was "upgraded" to accept the cross rams? They are a direct bolt on and the only internal change would be to retard the cam 4 degrees. |
Location: North Australia | Wow! hit $19.1K, 7 days out. 16 bids. Steve. |
Location: So. Cal | Is retarding the cam required to run them? If so, why? |
Location: Alaska | Retarding the cam is not required but if you look closely at the cam specs. the factory apparently did. It helps by moving the peak power to a higher RPM. I don't believe this was done on the later Chrysler letter cars with the "short" long ram because they had a more aggressive solid lifter cam. I didn't do this on my 383 when I installed the ram manifold but was not aware of it at the time. |
