How to remove window seal rubber
Apollo 61
Posted 2019-09-04 3:37 AM (#587024)
Subject: How to remove window seal rubber
5001001002525
How do you remove the rubber front and rear window seals on a FL with damaging them?
Does anybody have a video or advise on how to do this.
I have a few FL parts cars that I need to part before winter that I can practice on.
Posted 2019-09-04 8:16 AM (#587035 - in reply to #587024)
Subject: Re: How to remove window seal rubber
5000
you unlock them, then lube them up with something, push the bottom out, remove glass, remove seals.
to unlock you take like a plastic thin stick and open the seals up.
jboymechanic
Posted 2019-09-04 12:31 PM (#587047 - in reply to #587024)
2000100252525
Ken, if you have the factory service manual (FSM) for the vehicle in question, the procedure is explained in pretty good detail with pictures. I was able to swap windshields in my 1960 Plymouth following the procedure if the FSM. I used Goop original formula hand cleaner to clean and soften the gasket ahead of the removal, a popsicle stick comes in mighty handy as well. If you look at my member's ride thread for my Plymouth, I have some of the details about windshield removal in that thread. If you want to email or even call me directly, send me a PM and I'd be happy to give more detail.
Apollo 61
Posted 2019-09-04 2:36 PM (#587057 - in reply to #587024)
5001001002525
I will check out the thread. I will try the hand cleaner. The car I'm trying first is a 56 desoto rear window. If I'm looking at it right there is a rubber expansion string that kinda snaps into the middle? I will work the seal til it comes loose. Does the string remove in one piece? I don't have the service Manuel just the supplement Manuel. Will send a pm
60 dart
Posted 2019-09-04 3:47 PM (#587064 - in reply to #587024)
50002000100050010010010010025
i use an old cutoff round screwdriver , rounded off smooth and wd40 to help things go smoother
to clean up , i use original go jo and let it set for a day or two in a plastic bag , then wash ----------------------------------------------later
Posted 2019-09-05 11:46 AM (#587105 - in reply to #587024)
5000
https://www.youtube.com/watch?v=tLxNhI4U-e4
Apollo 61
Posted 2019-09-11 8:45 PM (#587405 - in reply to #587105)
5001001002525
Thanks guys. I was successful with a 56 desoto rear window. I'm going to practice on a Few more parts cars before I try my fury.
jboymechanic
Posted 2019-09-11 10:57 PM (#587410 - in reply to #587024)
2000100252525
Glad to hear it. How did it go for you?
Edited by jboymechanic 2019-09-11 10:58 PM
