Location: NY | Anyone have updates on where to get repo plastic lens? Searched the forums but the info is a bit dated. Thanks |
Location: Newark, Texas (Fort Worth) | There a re a lot of 'lens' on you car. What are you looking for exactly? |
Location: NY | Mainly looking for the clear plastic piece that goes in the trim attached to the grill. Also could use taillight, backup and license plate lens.
Thanks |
Location: Lower Mainland BC | NYFDX - 2019-10-12 8:14 AM
Thanks
Like these?
Front signal lights:
Pair:
https://www.ebay.ca/itm/1956-DESOTO-FRONT-BUMPER-GUARDS-W-LIGHT-ASSE...
Singles:
https://www.ebay.ca/itm/1956-DESOTO-FRONT-BUMPER-GUARD-TURN-SIGNAL-A...
Location: Newark, Texas (Fort Worth) | https://www.google.com/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&ca...
flAhUFOKwKHchACrUQjB16BAgBEAM&url=https%3A%2F%2Fwww.moparmall.com%2F1658158-1956-DeSoto-Chrysler-Wagon-Tail-Lenses-p%2F822-978(2-pk).htm&psig=AOvVaw3p
on-Tail-Lenses-p%2F822-978(2-pk).htm&psig=AOvVaw3pRotFZ3V-4QO9zYYLpeA2&ust=1570993082517969
https://www.ebay.com/itm/Mopar-NOS-Back-Up-Lamp-Lenses-55-56-DeSoto-... |
Location: Lower Mainland BC | NYFDX - 2019-10-12 8:14 AM Also could use taillight, backup and license plate lens.
I *WAS* thinking that the 56 Desoto wagon rear is much like the 55 Desoto rear. BUT NOPE. Sorry.
55:
56:
56D:
Great pics! The 56 looks identical to the one I have, minus the colossal amount of work it needs
(57669692433__14A5D23C-9054-4B82-9DB8-AFB8EA01007B.JPG)
Attachments ---------------- 57669692433__14A5D23C-9054-4B82-9DB8-AFB8EA01007B.JPG (123KB - 84 downloads)
Location: Lower Mainland BC | NYFDX - 2019-10-12 2:15 PM
Well, I hope you have a good budget because I could bust it for you.
Your lenses should be the same left and right and should be 1658 158, also used on the 56 Chrysler wagons. The good news I found a vendor that says they have them. The bad news. The price is outrageous.
"https://www.moparmall.com/1658158-1956-DeSoto-Chrysler-Wagon-Tail-Lenses-p/822-978(2-pk).htm"
(copy and paste this ^^^ from the ht.....to htm without the quotes into your browser)
Edited by 56D500boy 2019-10-12 5:34 PM
(56DesotoTailLightsAtMoparMall.jpg)
Attachments ---------------- 56DesotoTailLightsAtMoparMall.jpg (89KB - 90 downloads)
Location: Hayward, Calif | If your red lenses are still all in one piece and not cracked, get some rubbing compound and some really fine polishing compound and a dremmer with polishing pads and polish them out. I did this with the 59 Dodge lenses that were cloudy and they came out like new. Jerry |
Location: Lower Mainland BC | 59 in Calif - 2019-10-12 4:55 PM
Even if they are cracked and/or broken, as long as the fit of the pieces is tight, you can make repairs with Methylene Chloride and a fine syringe. Followed by 2000 grit sanding and polishing, etc. BTDT on an Audi taillight (or two)
This thread:
https://forums.quattroworld.com/s4s6/msgs/244993.phtml
Location: Lower Mainland BC | NYFDX - 2019-10-12 5:25 PM
$953-WOW.
Makes the Methylene Chloride and/or some polishing look pretty attractive, huh?
