Posted 2019-12-17 9:35 AM (#591727 - in reply to #591667) Subject: Re: 57 Plymouth Plaza 2 door. Not mine
I couldn't see the clutch pedal either, but the add says it's a manual trans car and you can see the gear selector shaft on the underside of the steering column. Springsweptwing has identified the giveaway, the handle for the overdrive lockout cable.
