  Location: Switzerland | Hi, I was looking for a rear dual antenna installation template for my new dual antennas on my gorgeous looking CRL D-500. Could not find anything on the web yet.
Does anybody have such a template or can give me the right measurements or good pictures of where to drill the holes ?
Thanks everybody for support !
Dani |
        Location: .Norfolk..Mafia.. ,England UK | If you have the correct Antenna's , it not for the Faint hearted , as Holes are massive,, I done mine After repaint,,,
(109.jpg)
(110.jpg)
(112.jpg)
Attachments ----------------
  Location: Switzerland | Yeah, thats exactly what I have. but where did you get that sheet of paper from ? with the exact location. If you still have it could you maybe scan it and send it to me. I will then be able to seize it on the computer to match the exact fit..
Thanks again Dani |
Sent you a Email with Attachment , hopefully you can print off as Full A4 size to be correct,, Also use your Mirror on the template to locate the 2nd Stud hole.. As i have taken template off my Dodge Royal which is currently stripped and 2nd Stud fixing hole has been welded over..
Here is some PICs to help understand my Template
Cheers Clive
(2.jpg)
(3.jpg)
(4.jpg)
  Location: SWITZERLAND | Nice Clive! Why not post as attachment in real size a scanned A4 PDF-File? Then can print on a transparency usable for both sides.
Many would be happy with. - SERGE -
PS: My CAD-template is still not ready and based on a Convertible (?).
Edited by sermey 2020-04-08 4:57 PM
      Location: The Mile High City | Theres a factory template for those. I have one on this thread http://www.forwardlook.net/forums/forums/thread-view.asp?tid=41650&posts=26&highlight=templates&highlightmode=1#M580128 Looks like the template pictured on this thread works pretty well too. I'd guess it would be the same for 1957 - 1959 Dodge, maybe Plymouth too?
Edited by Lancer Mike 2020-04-08 11:46 PM
  Location: Switzerland | I checked and scaled both sheets. The 57-58 template shows a different angle to the 59 and also closer position to the trunk opening. I doubt it will work. Maybe the posts then would be to close to the trunk door and not enough clearance is provided. I wonder if the geometric of the 57-58 models is the same, as for 59 models the rear fins have changed, as far as I know.
Dani |
      Location: The Mile High City | Good to know! I always thought those decks were virtually identical. |
