Location: Ohio | Looking for the following NOS molding clips
What makes this clip unique compared to the standard type are the 2 wire retainers, whereas most molding clips only have 1 wire.
Interested in singles or complete molding clip package. The clips must be NOS.
(Clip-a.jpg)
Attachments ---------------- Clip-a.jpg (225KB - 135 downloads)
| Got a part number? Or application? |
Location: Ohio | This clip is used on 1961 Dodge molding.
Researching the 1961 master parts catalog, believe that the clip part number is "6000835"
However, I have purchased clips that were listed under that part number from several places and they were NOT correct. In fact NOT even close resemblance, the clips received were totally different type.
The problem is compounded because if a vendor has clips listed as available, there's usually no details, photos or model application
Edited by Space Trukin Wagon 2020-04-20 11:18 AM
Location: Newark, Texas (Fort Worth) | Plastic: https://www.ebay.com/itm/Chrysler-1-1-1-4-Body-Side-Fender-Door-Viny... |
Location: Newark, Texas (Fort Worth) | Odd hook: https://www.ebay.com/itm/25-Dodge-Plymouth-Mopar-quarter-fender-belt... |
Location: Newark, Texas (Fort Worth) | Naw; https://www.ebay.com/itm/12-pcs-Plymouth-Dodge-Chrysler-push-in-belt... |
Location: Newark, Texas (Fort Worth) | Naw 2: https://www.ebay.com/itm/12pcs-Plymouth-Dodge-Mopar-fender-push-in-b... |
Location: Newark, Texas (Fort Worth) | Eh... https://www.ebay.com/itm/6-Dodge-Plymouth-Mopar-fender-door-belt-mou... |
Thanks for all the links / leads but none of those molding clips will work. Most end up being too short. Trust me I’ve been going through all of my miscellaneous factory clips, checking out other manufacturers etc. Have found a few that are close, (in fitment), but nothing has the unique set up of the original clips where the wire retainers are set at 90 degrees to each other. If find something that fits will probably end up modifying to make it work. Though first choice would like to try to find NOS ones.
Edited by Space Trukin Wagon 2020-04-20 11:41 PM
