Has anyone removed the rear quarter window on a 56 Dodge 2 door hardtop? I have looked in the parts manual at pic and in the service manual for info. The service manual says "remove the set screws that retain the pivot pin" I can see the pivot pin but am unable to find any set screws that may lock the pin in. How the heck do you get the pivot pin out???? HELP!
Posted 2020-06-05 10:35 PM (#599317 - in reply to #599298) Subject: RE: Rear quarter window
There are four bolts that hold the pivot to the inner quarter. If you have the quarter interior door panel off, they are in the upper left hand corner for the right quarter.
Posted 2020-06-06 10:17 PM (#599355 - in reply to #599317) Subject: RE: Rear quarter window
Thanks Ron. Some dum dum put a bolt instead of the proper pin.in the left side. I copied the pin from the right side and made one. Finished it today. Works
Del
