Location: Meridian, MS | All I have is the bellhousing, standard transmission, z-bar, and pushbutton delete panel to convert my 318 cid, Torqueflite setup to a standard transmission in my 1960 Dodge Dart. I need everything else: z-bar studs, brake/clutch pedal assembly, clutch fork, over center spring, all springs, boots, linkage, clutch, flywheel... everything. Also, if anyone has information on part interchange that would help... can I use other parts from other makes to help this conversion. Thanks Chris |
