What are you guys doing for wiper blades?
Mopar1
Posted 2021-01-21 11:37 AM (#607959)
Subject: What are you guys doing for wiper blades?
2000100025
'60 Plym.
Posted 2021-01-21 1:35 PM (#607971 - in reply to #607959)
Subject: Re: What are you guys doing for wiper blades?
50001000500
https://www.rockauto.com/en/catalog/plymouth,1960,belvedere,5.2l+318...
ANCO 3116 {#VCB16} 31-Series; 16" Info One of our most popular parts
Front; To install, use included 7mm Bayonet Adapter; w/ Replacement Style (Bayonet) Arm
Part image
$2.08
Add to Cart
VALEO 604467 Traditional Titanium; 16" Info
FitsFront Left; Armtype: Bayonet 7mm
orFront Right; Armtype: Bayonet 7mm (Only 3 Remaining)
Part image
$3.01
Add to Cart
TRICO 33162 {#601647} CLASSIC; 16" (405mm), 7mm Bayonet, 7/9mm Hook Type Info
Front; Original arm and blade inseparable, replace with both new arm and blade
Part image
$9.77
Add to Cart
Economy collapse
ANCO 14C16 14-Series; 16" Info
Front; w/ Replacement Style (Bayonet) Arm
Part image
$2.18
Add to Cart
VALEO 50016 500 Series; 16" Info
NicksGarage
Posted 2021-01-21 1:54 PM (#607972 - in reply to #607959)
1000100100
Here's my post on using the Trico Classics to refill my 1960 blades.
http://forwardlook.net/forums/forums/thread-view.asp?tid=73909
Mopar1
Posted 2021-01-22 6:51 AM (#608018 - in reply to #607972)
2000100025
NicksGarage - 2021-01-21 12:54 PM
Unfortunatly the metal backed refill was replaced by one that was plastic & the plastic broke.
Posted 2021-01-22 10:49 AM (#608022 - in reply to #607959)
50002000100100100100
Unbelievable but true, the rubber, the way it attaches to the wiper, is still unchanged for average new car wipers, so you can buy a cheap set for about any car and retrieve the rubber to use on your FL.
Mopar1
Posted 2021-01-25 10:17 AM (#608157 - in reply to #607959)
2000100025
was pressed for time. I was going to a car show 4 hours away with a possibilty of rain going over. Went to parts store and bought a Trico 16" assembly & took it apart like was suggested above. Turns out on my '60 Plym. that it is just short of fitting. Looks like 17" is needed. Turned out it didn't rain & I Rain Xed it just in case.
jboymechanic
Posted 2021-01-25 12:00 PM (#608166 - in reply to #607959)
2000100252525
Good information to know, thank you.
