| Will a sway bar from a 61/62 NY or 300 work on a 61 Plymouth?
Or will a 64 imperial sway bar work on a 61 Plymouth? |
Location: WHEELING,WV.>>>HOME OF WWVA | i have a 64 imp. sway bar i bought for my 60 dart but i think it may need to be mounted under rather on top
of strut bars like some 64's -----------------------------------later |
Location: Ohio | This is an area that I’ve researched extensively. Many of the later swaybar set-ups are a direct interchange onto the 1960-61 frame. One of the main differences is some used brackets welded to the inner frame and others were bolted in. This is easy to check by looking at the inner section of frame to see if there are already holes for where the brackets bolt in.
So in general, yes it can be done. There are some specific parts but, if you provide the year and car that the donor swaybar is from I maybe able to assist with info on what parts work. |
