| Removed from a '57 New Yorker. The complete power steering column, steering gearbox, pitman arm and steering linkage. Everything you need to add power steering to your car except the pump. Should fit a lot of 57-59 Mopar $150, huge and heavy pick up or you pay the shipping. Chicago area. |
| I have a good, working power steering pump out of a '57 Dodge to complete a conversation with this linkage (Assuming these are compatible with each other) |
| It should, thanks for mentioning this! |
Location: Alaska | I believe the steering column is longer in the long wheelbase Chryslers and Desotos than the Dodge and Plymouth. |
| gearbox is the same... long cars vs short cars have different attachments |
