Location: Waterloo, IL (near St, Louis, MO) | Hi all, finally jumped back in to the FL. Got a '57 Savoy V8 with a Powerflite and I'm looking to swap in a Torqueflite. If you have one (especially if you're in the midwest) please PM me. I'm in the Kansas City area. Thanks!
-Trogdor | |
Location: Meridian, MS | I have a Torqueflite for sale with parking brake assembly, torque converter, shifter cable, dipstick and bellhousing. I’m in Meridian, Mississippi. I replaced the front and rear seal and pan gasket. It leaks around the pan and where the shifter cable goes into the case but I think the o-ring I used is too small on the shifter cable and the gasket split when I cinched down the bolts. I drove around with this transmission about 20 miles and seemed to function fine. I just came across a cheap standard transmission and hardware so I pulled the Torqueflite and threw in the standard. I don’t have a particular price yet, what would you be in it for? I can send pictures if you need me to.
Thanks
Chris | |
