I have my Plymouth speedometer out of the dash and
I want to oil inside it, there is a screw about 3/4 of a
inch long coming out of the back that comes out
and inside and when you look in the hole where the
screw goes , looks like a place where you can put
oil in it . Am I correct with that ????
Thanks Alex |
Location: Ponder, TX | That's correct. The ones I've seen have a felt wick inside the hollow screw and only take a couple of drops of oil.
Edited by GaryS 2021-08-21 5:38 PM
You might want to download and "own" the 55/56 Plymouth Factory Service Manual (FSM) free from MyMopar.com
https://mymopar.com/service-manuals/
Bottom right corner of page 435 (436 of the pdf):
"SPEEDOMETER — Speedometer Oil. Oil tube
with wick on housing near cable flange, unscrew
oil tube. Saturate wick with lubricant and replace."
Thanks both of you gentleman
Alex |
