New User
Location: USA | My dad has a 59 New Yorker and wants to know what is the biggest tire that can be installed without much rubbing and changing speedometers? Thanks for the advice! |
Location: Branson, MO | Largest original size was 900x14 bias ply. Standard was 850x14 also bias ply. You can go to a comparison chart and check radials as well as different wheel diameters too. |
Location: So. Cal | When you say biggest, you should specify if you mean wide or tall. |
Location: Ramona, CA | I just put these 235 70R 15 Cooper tires on my 1960 Chrysler wagon. I haven't driven it yet but it looks like they'll be fine. I need to pull the old 9.00x14 spare out to see how the height compares.
(magnum_gt_wheel.jpg)
Attachments ---------------- magnum_gt_wheel.jpg (196KB - 123 downloads)
Location: So. Cal | That's a nice size for the big cars. I'm running whitewall versions with the same size on my '60 New Yorker. |
Location: Springfield, MO | I recently did this exact thing for my 1959 NY. I lucked out and got a new set of 225/70r14 with rims and hubcaps from a Cordoba from a man in the local car club that switched to alloys to replace the 14 rims I had. They are still small in diameter by 1 inch to spec, but the PO put 205/75r14 about 20 years ago and they looked dinky compared to what I have now.
Per Coker Tire BF Goodrich's 9x14 are 28.68 dia and 9 wide.
IMO the 225/75r15 is the closest you can get radial wise to the OE Tire specs. 8.9x28.3
A 235/75r15 will get you 9.3x28.9, which is still within a mile or two error on the speedometer.
I looked up the 9.00x14 bias tire specs from Coker Tire and used a tire size visualization tool online (I used tiresize.com) to find a modern size closest to the 9x14 OG in a 15 inch rim. Closest you can get that doesn't cost an arm and a leg in 14 inch is a 215/75r14 (8.5x27.7), but hardly anyone keeps these in stock and will have a a or two to be ordered. This is mostly used for trailers.
If you have aftermarket alloy rims I think your backspacing needs to be considered, which you would have to go to talk to a rim shop and take some measurements. I took some Coys 275/40zr20 and 245/45zr18 off of my Chrysler as well and removed the lowering blocks on the rear. with this setup, the 18 rims would rub the fender in tight turns and the rear wheels had to be removed from a lift and could not be removed by a jack.
Pic of the wheels on the car
http://imgur.com/pU4Z7h7
http://imgur.com/DXQCd7c
Old 205/70r14 wheels
http://imgur.com/su0pOPh
Edited by chstrumpetdude 2022-04-18 10:37 AM
Location: Finland | I bought these cheap 215/80-14 C tires for my desoto. Looked ok to me .
(IMG_3701 fwl.JPG)
Attachments ---------------- IMG_3701 fwl.JPG (39KB - 114 downloads)
Location: Springfield, MO | 22mafeja - 2022-04-19 12:29 AM
I am pretty sure those are like hens teeth in the US. Just Like finding a 235/75r14. If a tire shop can get it, they would have to custom order them. Your size doesn't look bad, but your speedometer would be off because they are still off by a little over an inch in diameter at 27.5. |
