| Hello, I've been trying to find information on decoding these punch cards, it seems everybody says something different. I also heard the codes changed yearly and information on one from 61' is scarce, could anyone help me out on this?
Thank you, LB
(IMG_4462.PNG)
Attachments ---------------- IMG_4462.PNG (209KB - 122 downloads)
Can you post the IBM card picture? |
| Just posted, was trying to figure out how to get the size smaller |
Location: Lower Mainland BC | 61MoPar - 2022-04-23 11:16 PM
Can you try that again, only as a .jpg. PNG files are very inefficient.
250 kB or less as a jpg
This is your png as a jpg but starting with a PNG is a bad idea.
(61MoparsIBMcard.jpg)
Attachments ---------------- 61MoparsIBMcard.jpg (101KB - 116 downloads)
| I converted the .pdf to a .jpg instead of .png this time, this is the highest quality its gonna get..
(jpg61card.JPG)
Attachments ---------------- jpg61card.JPG (65KB - 126 downloads)
UPPER ROW
SERIAL NUMBER 5217118287
5 = Dodge Dart V8 Engine
2 = Pioneer Series
1 = 1961 Model Year
7 = St. Louis Missouri Assembly Plant
118287 = Consecutive Unit Number, starting at 100001 and up
REGION 52 – no info
DEALER NUMBER 52770 – no info
BODY TYPE 522 = Dodge Dart V8 (5), Pioneer Series (2), 2 Door Hardtop Body Type (2); 6207 were produced
TRIM 314 = Gray Vinyl and Gray Cloth
PAINT PP1 = Vermilion (PP), Paint Scheme Monotone (1)
SHIPPING DATE 0927 = September 27, 1960 – almost early production car
SHIPPING ORDER NUMBER 09275036 = i. e. 0927 (Sept 27 above) and 5036 – 36th car built that day
MIDDLE ROW (NEXT TO UPPER)
1 = order code 441 = Solex Tinted Glass at all Window Areas
32 = TIRES = 7.50 x 14 White Side Wall 4 Ply, Rayon
7 = order code 347 = Deluxe Steering Wheel
2 = order code 282 = Powerflite 2 Speed Automatic Transmission
PLUS (SEE A PUNCHED HOLES)
STYLING 271 = a part of Paint PP1
TRANSMISSION 282 = Powerflite
ACCESSORY GROUP 301 = Heater, Back Up Lights, Left O/S Mirror, Prismatic Mirror, Radio Music Master
CUSHION AND BUMPER GUARDS 347 = Deluxe Steering Wheel
MIRRORS 385 = Right O/S Mirror
PADDED DASH 431 = Yes
TINTED GLASS 441 = Yes
WHEEL COVERS 501 = Regular (Deluxe would be coded 502)
TIRES 32 – see above
UNDERCOATING 588 = Yes
Have you got a data plate picture? |
Forgot the trim code chip:
Attachments ---------------- 1.jpg (67KB - 122 downloads)
Location: Lower Mainland BC | 61MoPar - 2022-04-24 12:02 AM
That is better but you left 185 kb (250 kB max - your 65 kB) on the table.
Check your Inbox here for my email address. Send the pdf to me an I will make you a better version yet for your files (and here).
| frwl - 2022-04-24 12:15 AM
Thank you very much for decoding, I will post a picture of the data plate in a little. |
| here's the tag
(61datatag.JPG)
Attachments ---------------- 61datatag.JPG (29KB - 122 downloads)
Braden: Here is a version that will max out a few monitor screens (at 1280 x 577). (It is as clear as I could get it (Sorry)):
Edited by 56D500boy 2022-04-24 4:45 PM
(BradenLs1961DodgeIBMCard_medium.jpg)
Attachments ---------------- BradenLs1961DodgeIBMCard_medium.jpg (120KB - 127 downloads)
| 56D500boy - 2022-04-24 1:37 PM
Thank you very much! |
Hello Landon, thanks for posting the data plate picture
A2 = order code 282 = Powerflite Transmission
H2 = order code 372 = Back Up Lights included in Accessory Group 301
Q5 = order code 315 = Heater included in Accessory Group 301
X2 = order code 382 = Mirror O/S Left
Y5 = order code 385 = Mirror O/S Right
I have no idea why they ignored solex glass, radio and the rest options on the cowl tag…
Also your car has manual steering and brakes;
There are 6207 Dart Pioneer 2 Door Hardtops V8 built (model 522) and 4231 Dart Pioneer 2 Door Hardtops L6 built (model 422)... |
Location: Lower Mainland BC | frwl - 2022-04-25 11:01 AM.
282 also shows on the IBM card. I was surprised that Powerflites were still around in 1961 but apparently the base transmission was the 3 spd manual (281?) with the Powerflite (282) and Torqueflite (283?)
extra cost options.
Dave: You will be surprise…
1961 Dodge and Plymouth Transmissions Availability:
281 = Transmission – 3 Speed Manual
282 = Transmission – 2 Speed Automatic
283 = Transmission – 3 Speed Automatic – V8
284 = Transmission – 3 Speed Manual Heavy Duty – V8
287 = Transmission – 3 Speed Automatic – L6
(pioneerinterior copy.jpg)
Attachments ---------------- pioneerinterior copy.jpg (90KB - 121 downloads) pioneerinterior copy.jpg (90KB - 127 downloads)
